Afternoon, morning or whatever time a day yall are reading this, Thanks for stopping by. I have some Auxbeam 3inch light pods that I am wanting to wire directly into the existing fog light wires. I am mounting it right next to the OEM LED fog lights. Will this overload the OEM circuit or blow a fuse? Any advice on the matter?
If I were you, I would wire them with a relay, and have the relay being activated by the fog lights turning on, and have the aftermarket lights wired directly for 12vdc off your battery, with their own fuse, this way you are only using the "signal" of the fog lights turning on to "switch on" the other lights through the relay. If that makes sense. Hope this helps.
Note that in most states, use of more than 4 front lights at the same time (2 headlights and 2 fog lights) will get you undesireable police attention. :(
