Actually BDS already makes a 4 inch lift for the rams with air suspension, not sure if it would work on the rebels though since they sit one inch higher standard than the other ram 1500 models. 2014-2015 Dodge / Ram 1500 Pickup 1500 4"" lift kit 1623H | BDS Suspension20 inch wheels have nothing to do with height. It comes with 33 inch tires and a raised susupention so it will look higher than a regular ram. Also the different bumper and wheel arches will make it look taller compared to the regular ones.
As for lifting. Your not going to lift it with the air suspension. It would first screw with the suspension and tuning and second screw with the computer. If you wanted to lift it more you would have to convert it to springs and a lift kit. But then why buy a Rebel?
I don't think it would be a problem. IIRC the Rebels stock height is the same as a regular 1500 in offroad 1?? Correct me if wrongActually BDS already makes a 4 inch lift for the rams with air suspension, not sure if it would work on the rebels though since they sit one inch higher standard than the other ram 1500 models. 2014-2015 Dodge / Ram 1500 Pickup 1500 4"" lift kit 1623H | BDS Suspension
You are correct. The Rebel's normal height is off road 1 for everybody else. I know they mentioned changing the geometry a bit in the front to accommodate the increased ride height. Not sure what they did though.I don't think it would be a problem. IIRC the Rebels stock height is the same as a regular 1500 in offroad 1?? Correct me if wrongActually BDS already makes a 4 inch lift for the rams with air suspension, not sure if it would work on the rebels though since they sit one inch higher standard than the other ram 1500 models. 2014-2015 Dodge / Ram 1500 Pickup 1500 4"" lift kit 1623H | BDS Suspension![]()
