1 - 11 of 11 Posts
Does anyone know where I can get a overhead console with black trim with Homelink? My 2016 Rebel does not have the Homelink option and I would like to add it. All I can find are 2010-2015 units with the beige or silver trim. I do have the power rear window switch and lights in mine, so there is power. Thanks
Not sure about replacing the console. If you don't find out how to do it, or you feel it's too much to do, you can always just get a homelink-based universal remote that will work with any garage door, and use that. Basically the same thing as you can purchase in the vehicle, but you'd just clip it on your visor. One such set of products here:
https://www.liftmaster.com/for-homes/accessories/remote-controls
Discussion Starter · #3 · (Edited)
John, Thank you for the reply, But I already have a door opener that clips on the visor. I have the the Homelink in the Challenger and Jeep, and just like the feature of it without a remote hanging on the visor. And the wiring part will be a piece of cake, as I am an industrial electrician.
DH61 - Not to derail the thread but do you think the wiring harness is already in there for the homelink? My truck came with the manual fold trailer mirrors and they really are too big for my use. I am toying with changing them out with the stock size powerfold mirrors. Thinking/hoping that the harness might be in there already and all I would have to add is the fold button and the mirrors. Wishful thinking perhaps. Anyway I need to find out from somewhere what the deal is, the dealer was not all that helpful.
Ackrebel, I think I should be good to go as far as wiring goes. I looked at a photo of the wires in the console area that I took when I took it down to run the coax for my Ham Radio antenna today and I see the four connectors I need. The main connector that goes into my compass module has the same three wires that is used to power the compass/homelink module. (Power, Ground and Signal wire to the lin.) I also pulled the console down again, and confirmed the connector, and saw that I can snap the black outer trim off my console, and put it on the new one that is gray when it gets here. Since no one wants to sell a all black one.
I would pull your left door panel and see if there is a connector on it for the mirror switch, and one for the mirror. I pulled my door panels to replace the junk stock speakers with Kickers, and found they came off really easy. Let us know what you find out.
Right now I am still on the fence about the mirrors but will probably pull the door panel at some point just to see if I can make the mirror change. Thanks. Good luck with your install.
Well Good news. I picked up a new console that was labeled for a 2013-2015 Ram. But it I could only find one with a gray or tan trim, so I put my black trim on it and it works perfect. Now to install the HID next. :D
Dodgehemi61,
I'm happy to see you got the console to fit and work. I just got a 2018 Rebel and didn't realize that it didn't come with the Homelink and was considering buying one and changing it out. Two questions for you. Was the tan trim easy to switch with the factory black one because all I can seem to find is the tan trim. And did the new console just plug into the factory harness or is custom wiring needed for the Homelink to work?
I just added to my 2017 rebel. The outer tan trim is very simple to remove. It just simple pops off on three sides and then you simple slide it off then replace in reverse with your own trim. The homelink itself is simply plug and play with no custom wiring needed. You unplug your compass module which uses the same wires and plug as the new homelink module.
1 - 11 of 11 Posts
