Removed that ridiculous antenna!
10385 Views 17 Replies 14 Participants Last post by  Dodgehemi61
2
Got this stubby! Best $25 investment yet.
See less See more
1 - 18 of 18 Posts
Went with a 14" shorty, seemed a decent replacement. I think a lot of members have swapped out that silly silver flag pole.
not as bad as lift kits and tires
Reactions: 1
I haven't even gotten the truck yet and I bought a replacement antenna for the silver flagpole..
http://www.amazon.ca/gp/product/B00651BLTM
14" antenna will look much better than the 31".. I didn't want to sacrifice FM reception too much.. even though I have a lifetime subscription to SiriusXM (bought that back in 2004.. best 500 bucks I had spent at the time!)
That's actually a lot cheaper than I was expecting. Guess it gets more expensive if you go with a shorter one like Falselink's.
Can you tell me the post you put out there about the antenna, will it fit the 2016 Rebel, as it said on Amazon that it wont.
Clicked on the Amazon link....
See less See more
Reactions: 1
How's your reception with the short antenna?
Kinda like a girl in a bikini with no belly button
Another option and is what I do most of the time is to.....
Just cut down the factory antenna to the size that you want. Then scuff it up a bit so some Black Rustolium or what ever paint you want to use will stick. Then pop the threaded end through a cardboard box, this holds it up straight so you can get a complete and even covering on it and this way you don't get any paint on the threads. Do a few coats after all is good and dry put a vacuum cap over the tip that you cut. then screw it back on and you have yourself a basically free custom short antenna that you deside the exact length and it still get good reception..
There, that's my part to adding to this thread.... enjoy...
Bill
Reactions: 2
How much can you cut down before it affects the reception?
It would depend on how close you are to your preferred radio station.
Cut in half if you are. Antenna size is specific to a frequency or frequency range its designed for. You want to keep the length a relative multiple or ratio of the bandwidth.
Looks good but I like the stock one so I know if I clear the antenna I know the truck will fit in a garage.
Reactions: 1
An antenna that is tuned to a frequency will perform better than a untuned antenna. Here is a formula that will let you tune an antenna for perfect reception and transmission if needed. Take your receive frequency, lets say the middle of the FM band 100 Mhz and divide into 468 then divide it by 2, this will be a perfect 1/4 wave antenna. 468/100=4.68/2=2.32 feet or 27.84 inches.
Reactions: 1
1 - 18 of 18 Posts
