oh well. already bought the truck.... drive carefully
Safety ratings
go there and do some research.
here are my findings.
they changed the test in 2015. it used to be a moderate overlap front.
in the moderate overlap front the current generation ram did well. it received good ratings (equal to the current f150 in this years test). the f150 from that test (comparing 2014 f150 (steel) to 2014 ram in moderate overlap test) did worse than the ram.
right when the test changes in 2015 guess what else happens? ford releases the new aluminum f150. the test changes to the small overlap where everyone but the f150 does poorly.
not crying a conspiracy here im just pointing out the data is very skewed and you can't objectively make the call that any of the other brands are unsafe based off the most recent "test".
to summarize:
in 2014 and prior years the test was moderate overlap and the ram did well, better than the 2014 f150.
in 2015 the test changed to small overlap the same year the new aluminum f150 debuted. now the f150 is on top and everyone else is doing poorly in the new test.
make your own conclusions.
