Since someone thought it was a great idea to drop the front sensors and just leave us with rear sensors, is it possible to install factory sensors in the front and have them operate as if they were installed from the factory? Has anyone installed any front sensors on there Rebel (either OEM or Aftermarket)? Details if so?
I've got an Uncle the owns/runs a very large auto salvage company so I'm sure I could pick up whatever parts go with the front sensor system from his place.
I'm sure it could be done but would it be worth it is the question. I'm sure it would be costly adding the wiring if the plug isn't up there already. Also it would require the dealer to flash the ECU so it would work. Than you would probably want to add the button to turn them off like how our trucks have the button to turn them off. My buddies Laramie has both front and rear park sense and he has 2 buttons, one to turn off the rear and one to turn off the front.
