21 - 32 of 32 Posts
A 30" curved light bar fit perfectly with a bit of modifying of the 2 mounting brackets with it I don't right now have pictures of it at night but will in 9 days
I used the same brackets that the light bar comes with just drilled holes in the side of the brackets used the bolts it came. But because it was curved it mounted perfectly to the mounting bracket of the bumper cause it's slightly on an angle.
well i mounted a 30" single row led light bar in the front bumper. and this upcoming week i will be mounting a 50" curved light bar on the roof aswell as two flush mount pods in the rear bumper for reverse lights and work lights. all are wired to some nice rocker switches mounted in the center counsel.
do you have pics?
30" speed demon black ops curved, very bright !!!!!
Can you give me some details on how you mounted your LED bar there in that space where the honeycomb insert it? I was able to unscrew that whole plastic piece, but didn't have enough room behind the bumper to get it out of there.
Did you do any cutting drilling? What about brackets? Any guidance would be greatly appreciated!
Hey Randy I dremeled out the honey combe then drilled and tapped into the side frame there is a lot of test fitting the brackets I had to grind down the bracks on a slight angle to fit the curved bar but the finished product fits very nice. What I would do first is get the whole light bar assembly with the brackets that come with on the light bar and test fit where it would fit nicely. I ended up tapping it 1/4"
21 - 32 of 32 Posts
