Has anybody replaced the following that can advise if I need can-bus or not to avoid any warning codes on dash.
Reverse/back up lights = 7440
Tag / license plate lights = 194
Overhead bed rear cargo = 921
Also if I do just pull the bulb to check, how quick will the warning code shine?
Thanks
its a 2017
I think you need CAN-BUS for the license plate. I put some in there that don't have it (the same ones I put in the interior), and it does generate a message each time I start the truck.
i changed license plate (168), 3rd light or you may call bed light (921), ram-box (168), map light (168), upper glove box (168), footwell (168), domelight (578)
no error or message and i did not put any canbus. i have 2018 model
