It seems to be working a bit better now, the one thing I did notice is with the stock intake manifold the mass airflow sensor locks and in a certain direction
With the Cold air intake kit you can rotate this mass airflow sensor in any direction I'm not sure if it would read differently if it's not facing the Air flow correctly?
I just know with the stock set up it rotates in and will only lock in so that the incoming air has to run by the bottom loop of the sensor if that makes sense ?
I might call K &N just to get their opinion
It is just a temperature sensor.. it being rotated may change the temperatures read by a small amount, but would not keep MDS from being engaged.
The truck will stop going into MDS if there is an engine code (have experienced even a pending engine code to cause MDS to stop on my old 2008 daytona)..
remember on our trucks.. ECO doesn't mean MDS is engaged.. there are a couple of conditions that cause the eco light to come on.. and even with MDS not being engaged, it's possible to see some pretty good mileage.. (noticed MDS is really difficult to get to come on at 130-140km/h.. not that I drive that fast of course.
