Hey guys, looking to upgrade wheels and tires on my ram rebel. I think I have finally decided on a size and before I make the jump I wanted to ask your opinion if it will work. The wheel size I am thinking of doing is a 20x10 with a 0 offset. I am looking to hopefully put 35s on there too. I have narrowed it down to NITTO RIDGE GRAPPLERS or TOYO RT's. I don't know much about leveling, lifting etc, so ideally want a setup that will be plug and play essentially with no rubbing or additional mods if possible.
Thanks everyone
Most guys that upsize to 35's note some rubbing without some lift adjustment.
However, there are also reports that 34.5's don't rub. To get a 34.5 you would normally put on 315/70r17 tires. Since you're planning to change to 20's, you'll need to look around some more if you want to avoid the rubbing.
