Discussion Starter #1 (Edited)
I've got a new 2017 and I just checked my tire pressure.
The sticker says it should be 55 PSI Front and 45 PSI Rear.
Tire pressure from the dealer is Front 55-53. Rear 60-57.
*** Edit the readings are when the tires are cold.
Mine was 40 in the front and 50 in the back. My TPMS light was on.
So I did them myself. Dealers just don't care !
55 front and 45 back is correct
Super Moderator
55-45 is correct. Always go by the door when running OEM tire size/specs.
At least tire pressure is something you can fix yourself. Some dealerships just don't care enough to check these things.
But the drywall dust in the bed is something else...
This is an old post but I just picked up a 2019 rebel... tire pressure sensor says 64 front/rear... drove it 300 miles home and thought it felt a bit stiff. I have a digital gauge and it reads at 58 all tires.... i dropped everything to the 55/45 according to my gauge, but on starting the ram, dash still shows 63 all tires....do you have to reset pressure, or drive it to update the reading?
