Ok, I understand that we can add different links to raise the height of the truck.
MY QUESTION: Why can't front "pucks" or spacers be added to level the truck out?
This would not interfere with the links or PCM. If anything, it would compress the bags for a MORE smoother ride....right??? I'm just thinking out of the box.
I am NOT a professional mechanic and are barely a shade tree mechanic so grade my comments accordingly.
PROFESSIONAL TECHS!!!! What am i missing here?????
I'm not looking for a 4 corner lift, just raise the front to level.
Thanks.
Spacers are the absolute worst way to lift/level a truck.
I don't think that would work because the air suspension sensor arms wouldn't bet getting the correct readings and would be outside of their set parameters. The only way I can see that working is offsetting the sensor arms the same thickness of the spacers. That way it would be fooled into thinking the truck is factory ride height but actually will be sitting higher.
