Is anyone using the ready lift 3.5 sst lift kit?
If so any info on ride quality? I'm planning on running 35x12.50x20 -18... and I read that when using that kit you don't need the preload spacer only the top mount spacer is that true? Thanks in advance
I highly dont recommend the readylift for the rebel... when you remove that preload spacer it will have a rake appearance. Get a lift kit that was made for the rebel like the fabtech 3". I have had both and the readylift will make it extremely stiff and I will cause damage to you lower control arms. So glad they took the lift kit back and swapped with the fabtech
